Turning shaft
Turning shaft
Just wondering if anyone has ever turned the upper idler shaft to bring the unworn side to the top
seems like this could work ?
440,
I was sort of wondering the same thing. I have two pretty much sacked out on my 420. I just don't have a big press, or I probably would have already tried. The press is on the drawing board. Right behind the 420. Carts and horses and stuff, or chickens and eggs. I never could get any of that quite right.
Gary
Gary
upper shaft
Found the same problem on our 420. Obtain the upper replacement bearing. start laying in arc welder beads/mig beads roughly to the required dimension and roughly finish with a large flat file. You'll probably find the very outer end of the shaft is not totally worn down and will make a good welding guide. A mic or caliper will help. Approx 2-hours work and polishing machinist's tape finished it to a near perfect fit. good luck
That's good to know. I only tapped on it lightly, and backed away. I haven't had time to work on any of it, though. My son needed a shop, so we built that, and now we have some travelling in front of us. I hope to get back to it ernestly in September.
How much are the shafts? Bushings? This is for the upper roller.
Gary
Gary
Users browsing this forum: No registered users and 90 guests
