Take off distributor cap, remove cover to get to points. Turn ignition to the run position. Operate the points and see if you are getting a spark between them. If so, try starting and see if you still get a spark. If you are getting spark, remove a spark plug, ground it, and start to make sure you get spark at tip.
If those test work, make sure you have fuel.
Ignition
- JD440ICD2006
Ignition
- JD440ICD2006
No fire at that point means you have an electrical issue. Trace the wires and make sure you have solid connections and a good ground. Start at the battery with a voltage tester, or anything to indicate power. You will find where the break in connection is.
Good luck and keep us posted.
Users browsing this forum: No registered users and 126 guests
