Johnneypopper
Post
by Johnneypopper » Fri Jul 18, 2008 10:46 pm
im trying to loosen my brake pedal and looks like the pedal is held on the shaft with a pin through it so do i split the housing awayto get inside and work from there or what i thought it rotated on the outside shaft but it looks like it doesnt shes totally solid so im up for some help thanks
Johnneypopper
Post
by Johnneypopper » Sat Jul 19, 2008 8:40 pm
okay i pushed the pin out that holds the brake pedal on the shaft it looks like the shaft goes through to the other side so does it couple inside there is what looks like a inspection hole by the brake pedal but i cant see anything so im stumped please help
thanks
- Site Admin
Post
by Lavoy » Sun Jul 20, 2008 10:14 am
The brake pedal shaft goes through a hollow tube that the clutch pedal hooks to, often they are rusted together. You can try lots of penetrating oil, and then work it back and forth to try and work it loose.
Users browsing this forum: No registered users and 186 guests
