Injector leak
Injector leak
Im finally getting my 1010 back up and running after 2 years apart (dont ask ) and got it started tonight. The injector nuts were really tough to loosen but I eventually got it bled and running. Problem now is that 3 of them are leaking a little right at the nut. Is there anyway to get this to stop, short of buying new injectors? I dont want to overtighten them as they were very low torque from what I remember.
Hmmm , I don't know what the end of the line looks like but if it is a cone seal , tapered cone on the line into a cone seat , then the best bet would be to take the nut all the way off and clean the threads lube them slightly and tighten them them back down and see if it stops leaking before replacing the injectors . I had the same problem on my 6.2liter diesel in my '83 GMC pickup truck and that cured the leak . Sometimes the line gets tweaked a little bit and the cone and seat do not align correctly and that can cause a leak . JMTC. Dan
1956 420C with GSC blade
Users browsing this forum: No registered users and 124 guests
