The throw out bearing carrier JD pt.# M 1617T. Had both final drives in the tractor and in adjusting the throwout bearing on one side the bolt hole stripped out. That is one problem. The other problem / question I have is that when you are adjusting the throw out bearing, once you slide the bearing out aginst the fingers of the clutch, you are almost out to the end ( with the 5/16 bolt ) of the part listed in the book as the cam pt. # M 1616T. Looks like the carrier needs to be approx. 3/16 to a 1/4 inch longer. Have you had this type of problem or any ideas what could be wrong or suggestions / modifications?
Throwout bearing carrier
- Jimmy in NC
Users browsing this forum: gaspumpsam and 128 guests
