No, you're not defying science - just mssing something along the way.Tim_in_IA wrote:
I am defying science I guess and I am doing all the steps. Trust me.
So do I buy another cap then?
I'm not trying to sound arrogant, or like a know-it-all - but . . . it's a pretty simple system without too many variables. Like anything though, something is only simple when you fully understand it, and/or have experience with it. There are many things in other areas that are complex to me, and simple to other oeople. That's just the way it goes.
In your case, you've got spark when you eliminate the cap and rotor - but how much spark? Keep in mind it takes a cetain amount of high voltage to travel through that rotor to the cap, and takes less whey it's bypassed. So, you need to determine is your spark is low to start with, or is correct and you have a cap and rotor problem.
Just take a spark plug and either break off the ground electrode, or bend it way out of the way. This way the plug has to jump a near 1/4" gap. If all is working as it should, your coil can jump this extended gap. If not, the spark is too weak and your problem is somewhere else - and not caused by the cap and rotor. Checking for spark with a properly gapped spark plug out in free air is never a good test.
