I am starting to put my 420 back together and was wondering about the spacer, Part #M2814T. The spacer does not get tight. When the nuts are tight the spacer still swings up and down. I this supposed to do this or is it supposed to be tight.
Just wondering if I to repair/replace this as well.
Front idler braket Spacer
- joeturner1977
- 430 crawler
-Joe
1958 420c w/mc60 blade
- joeturner1977
- 430 crawler
- joeturner1977
- 430 crawler
Now that the brackets are tight to the axle shaft there is about 1/8" of side clearance on the ends of the spacer. It looks like the bosses around the 7/16" holes on the inside of the bracket are worn from the loose spacer swinging. I will shim between the inside of the bracket and shoulder of the spacer with some washers and tighten the nuts.
Thanks Again This Site Is Awsome, Its Like Getting Tech Support From People Who Know Something
-Joe
