timing gears
timing gears
I have a jd1010 crawler loader gas. I hear the 2 timing gears on the diesel models need to be near perfect to run well but how about the gears on a gas unit ? I'm rebuilding my engine and I note wear on them. Does anyone have a new set for sale at a reasonable price ? thank you, phil
Re: timing gears
I've been around 2010s since they first came out from Deere, and I never heard that claim about the timing gears. Worked at three Deere dealerships and this is the first I've heard it. Any Deere with a Stanadyne rotary pump can benefit from the static timing being bumped up a degree or so after the engine gets some general overall wear - but nothing like that story. In fact, I recently had to do the same with my Cummins diesel in my Dodge truck.phil morrissette wrote:I have a jd1010 crawler loader gas. I hear the 2 timing gears on the diesel models need to be near perfect to run well but how about the gears on a gas unit ? I'm rebuilding my engine and I note wear on them. Does anyone have a new set for sale at a reasonable price ? thank you, phil
Re: timing gears
jdemaris wrote:I've been around 2010s since they first came out from Deere, and I never heard that claim about the timing gears. Worked at three Deere dealerships and this is the first I've heard it. Any Deere with a Stanadyne rotary pump can benefit from the static timing being bumped up a degree or so after the engine gets some general overall wear - but nothing like that story. In fact, I recently had to do the same with my Cummins diesel in my Dodge truck.phil morrissette wrote:I have a jd1010 crawler loader gas. I hear the 2 timing gears on the diesel models need to be near perfect to run well but how about the gears on a gas unit ? I'm rebuilding my engine and I note wear on them. Does anyone have a new set for sale at a reasonable price ? thank you, phil
my jd dealer said this when i inquired about buying new gears.
not nearly that much wear just enough to see and feel. if they are not that critical i may use them. also i found a new crank gear but not the cam gear. can i replace just the smaller crank gear that shows more wear?jtrichard wrote:unless they are worn down to thin as razors they should be fine how much wear? do you have?
Yes, pretty much applies to any diesel. If you adjust the injection pump to make up for wear and slack, the cam and valve timing can still be a bit off, but I've never seen it make any difference in performance- and I've tested many on a dyno. And, to be techical, you can also make up for late valve timing by the way you adjust the valves - but it's not worth the bother.Ray III wrote:The engine only runs one way so slack in the timing gears does not matter as long as timing is set with the slack taken up (engine slowly turned to the timing point without backing up).
Users browsing this forum: No registered users and 107 guests
