country53
Post
by country53 » Wed Jun 03, 2009 1:28 pm
Is there any way of greasing the clutchpedal/brake pedal tube? My crawlers tube rust/seizes together such that when you depress the clutch the brake pedal moves too. I lube it from the outside but I doubt it does it much good. Took it all apart 2 years ago and cleaned and polished and reassembled, lubed it lightly while apart but I think its ready for some more.
- Site Admin
Post
by Lavoy » Wed Jun 03, 2009 2:11 pm
If assembled about all you can do is spray lube from the outside. You can remove the brake pedal and slide the brake shaft sideways a couple inches, this might give you enough room to put some anti-seize on the shaft. I normally give them a healthy does of anti-seize if I have them apart.
Post
by jtrichard » Fri Jun 05, 2009 10:25 pm
i dont know that machine but you might look and see if you can drill it and install a zerk so you can grease it once in a blue moon? just a tought
country53
Post
by country53 » Mon Jun 08, 2009 9:52 am
I lube it from outside by using kroil then I use 30w. it works. I thought maybe there was a zerk somewhere I was missing. I completely rebuilt the dozer I didn't plan to at first but it became necassary. When I take it apart again(notice I said when and not if) I will probably change the material the shaft is made of to ampco or something like that to prevent seizing.
