need help!!! 1010 injectors??
1010crazy
Post by 1010crazy » Mon Jul 27, 2009 10:09 pm
Hi guys, I am new to the site but the message board here has already tought me tons of great info. There is 1 of many questions to come Im sure :) I just bought a 1010 diesel that smokes way to much. It seems to be unburnt fuel, I am guessing bad injector but my mechanic lost all his manuals in a flood and we cant find any specs on the injectors i.e. release pressure. Anyone have these specs for me?? not sure of injector brand but it is held in with a threaded cap if this helps. Thanks guys
ps
old deeres never die until the owner goes broke :D
glash62
1010c injectors
Post by glash62 » Tue Aug 04, 2009 5:39 pm
hi i sent you a post but i don't know if you got it. endurance power equipt. lincoln nebraska i don't know the # but they rebuilt mine for about 40.00 each that was parts &labor they tested nozzles the guys name was dan. check you turbulance chambers to make sure they are not cracked. you will have to drain your antifreeze there are 4 bolts on each injector and orings . good luck glash62
