i have been hooked on the 2 cylinder john Deere crawlers for about 2 years now and i just picked up a 420 for parts and it has 2 different inner final drive housings.i know its common to see 420s on an mc or 40 but these are quite different than what i have been seeing. one i think might be a universal housing.it has 2 barrel type caps to adj the throwout barring.one front and one rear also a 3/4 pipe plug at the bottom wear the brake rod would be if it was installed on the opposite side.the other one is very strange it has no barrel type covers at all not even the raised boss in the casting wear the caps wood screw in??.someone used a torch and burned a hole about the size of a quarter to adj the throwout barring.it dose have the 3/4 pipe plug on the bottom like the other side.both have the standard square axcess covers on the top.
thanks for any info.
420 final drive castings ?
- mapaduke@yahoo.com
nothing crawles like a deere
Users browsing this forum: No registered users and 47 guests
