Reverser oil level
Reverser oil level
On a 420 with a reverser (non-hydraulic), is it possible to check the oil level in the reverser without splitting the tractor? If it"s not possible, how important is it to check the level, since its so difficult to get to?
57 420c 86 Ford 4600
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
The oil level in a gear type reverser is never checked. The trans oil flows down a galley on the LH side of the transmission case, out a hole in the trans case through the input shaft bearing into the reverser maintaining the level. The main thing on a gear type reverser is they need to be initially filled with oil if removed or rebuilt. If not, they will be ruined before enough oil will flow in to fill it up.
Users browsing this forum: No registered users and 96 guests
