Considering buying a 1010 Dozer with 6 way power blade and was wondering if it would be a "bolt" on for a 440? It is the inside mount blade.
Thanks,
Mike
1010 inside mount 6 way blade onto 440?
Chains, rollers, front idlers, upper idlers will. Unless you have a very high serial number 440, the sprockets will not, nor will the finals likely fit. Internals of the finals are all different, some outside pieces may fit depending on serial number of both machines. Engine, reverser, and trans are completely different.
joy stick on a 440
I have 440 dozer with an inside blade and a six way joy stick control. The control looks like the one in the pic. that is in the JD whisperer message from a couple of days ago. I assume mine is from a 1010. I like the control setup, it works well. I rebuilt the linkage on the joy stick last year, looked alot harder than it was.
Users browsing this forum: No registered users and 122 guests
