440 crank case oil coming out of oil dip stick
Hello,
I have a 440 icd
I noticed that there is oil coming out of the dip stick oil hole.
Get worse with rpm.
Seems to want to shoot out, even with dip stick in place.
Any ideas???
Maybe blower seal to block is leaking????????
What do you think?
Scott in wa.
I have a 440 icd
Get worse with rpm.
Any ideas???
What do you think?
Scott in wa.
crank case pressure????
The engine runs great with loads of power with clean exhaust.
Black smoke only when under a heavy load...
What do you think????
But.... I do notice that there is no blow by coming out of the valve cover vent cap any more.
Maybe it’s plugged up??????
Scott in wa.
crank case oil out of dip stick hole
Have you ever seen this before??
Where is the vent hole on the block?
I think there is a small copper tube that screws into the side of the block its on the opposite side of the blower , the end just hangs down. I bet that’s it.
1. what about theory that the rings are letting pressure into the crank case?? (The motor runs great)
2. Is it likely that the blower is bleeding air where the fuel pump is bolted to the block?
3. Is this condition related o the runaway condition that I have heard about???
4. ??????????
I have to check it out tonight....going to try and use it Sunday...help..
then she goes down for steering clutches
4. ??????????
Scott in wa.
run away
Yep I have seen allot of posts about that.
I was just wondering if this is a pre-curser to that condition.
I called the Detroit shop about the problem.
They said check all breathers and drains, most likely the problem.
We will see
Scott in wa.
We will see
Scott in wa.
Scott in wa.
good for now????
changed oil, blew out the crank case breather, and cleaned the breather on the valve cover.
Added some marvel mystery oil to it.
No more oil out the dip stick.
hummmmmmm.
Still not sure what’s going on.
But I do notice
Condensation or a bit more than that dripping from the breather ontop of the valve cover.
Almost like a slight amount of steam.
The oil in the crank case was clean not milky, just oily black.
Ran it an hour at 190 deg temp,
What do you think?
hummmmmmm.
But I do notice
What do you think?
Users browsing this forum: No registered users and 103 guests
