I am trying to find the correct part number for the coil, condensor and points for my JD 440 Gas Dozer.
I replaced my Radiator and solved the cooling problem. Now I cannot seem to get it to start correctly. I had a local mechanic replace the fuel line, filter, and coil, condensor and points, He was able to run it with no problems, but when I made it down to run it, I could get it to start, but after about ten minutes, it died.
thanks for the response.
R/ Jorge
Correct part numbers 440 gas Dozer
- Paul Buhler
I'd check the wiring, starting switch, and connections before swapping out the ignition parts if they were replaced by your mechanic. Old wires hide problems and can be a PITA, but are not too expensive to replace or override in the testing process.
I had a nagging starting problem on my 420c last year that was resolved by replacing the 9" wire and connectors between the coil and distributor - less than $1.00 and a few minutes to do. Good luck . Paul
If you are considering the coil and points as the problem, you might want to read the following thread on this board:
http://www.jdcrawlers.com/messageboard/ ... sc&start=0
In the thread, a number of members offered their advice on gas engine electrical ignition problems.
Users browsing this forum: No registered users and 79 guests
