air filter for mc
- millertym2
air filter for mc
Does any one know what aftermarket air filter would fit on a MC? I still have the oil bath filter but want to run a regular air filter to use for everyday use.
1952 John Deere MC
The first thing I think of is a precleaner. That's the bowl-looking thing that goes on the top of the inlet pipe in place of the screen cap. That has no element in it, though. It's meant to keep the larger stuff out of the oil bath, as in field tractor use and not so much crawler use.
There are no paper element filters for the older machines. I suppose one could remove the oil bath unit and then retrofit a paper element can from something else in it's place. That's all I can think of anyway.
Later!
Later!
Have: '58 JD 420c 5-roller w/62 inside manual blade
Have: '78 JD350C w/6310 outside manual blade
Also Have: 1950 M, 2005 x495, 2008 5103 (now known as 5045D)
When I got my first 440ICD it had no air cleaner, just the pipe back from the blower. I went to the local Industrial Baldwin Filters Dealer and he came up with a round metal can w/pleated air filter inside with about a 2 1/2" rubber lined outlet. The can is about 8 in dia. and height. I got a muffler shop to make me a new adapter pipe, had to expand one end of pipe a little, cannot remeber if the expanded end was to fit the A/C or rubber elbow to the blower. Made a little bracket to hold it off the fuel filter. The whole can is replaceable and it is in the area where the oil bath should fit. I can go look for a number on it.
- millertym2
Users browsing this forum: Bing [Bot] and 35 guests
