Winches
- mapaduke@yahoo.com
Thanks, will any winch swap out between 40, 420, 440, ? I know the 440 has heavier finals but are the mountings and dimensions the same? Is a 440 considered offset pto?
What I am getting at is this; There is a 40 locally with a winch- will this bolt right to a late 440 (pto, brackets, mounts, and all) ?? It is said to have worked fine last time the crawler ran...but you all know how that goes!! Anyway if it will mount correctly I would like to go look at it this weekend, Thanks.
Just found out it is a Holt winch...google turned up very little. Anybody know anything about them. Was told the controls on the fender need rebuilt and it should work, but again...we all know how that goes. It sounds similar to a gearmatic with a master cyl and 2 controls. I'm just afraid if it needs more, parts will be unavailable. Man these crawlers are addicting! I will post some pics either way. Thanks again.
- Willyr
My tractor came with a garwood 10,000 pound winch. The tractor was on a tree farm.
A owner prior to the fellow I bought it from (according to locals) was notorious for retrofitting vehicles / tractors with diamond plate and military OD green. Hence the color on the back end. He also made some interesting cylinder mounts that double as a winch mount.
former owner of a 1956 420c
Winches for 440 Diesel
I have an 8a and an 8G. I need Brake band assemblies for both. Also, when I get one or both completed I will part out the other. Any help will be appreciated.
Users browsing this forum: No registered users and 82 guests
