Final drive/sprocket bearing
- tuney443
- Contact:
On my 59' 440 track loader,the 1 side,the sprocket is wiggling around,actually it is hitting the bottom roller some.What kind of keeper holds her in,bearing[s],where to get parts,difficulty of repair,etc. Thanks.
Found the skull to the mastodon in Hyde Park, youngest one ever found so far in the world in 2000.
JD35D midi exc.
JD410G TLB
JD450D Dozer
2 JD 440 track loaders
JD 420 track loader
JD 450C track loader
JD35D midi exc.
JD410G TLB
JD450D Dozer
JD 420 track loader
- tuney443
- Contact:
Or maybe even grenade itself. Yes kahuna,I know better than to operate it,just looking to see what's involved for the repair.
JD35D midi exc.
JD410G TLB
JD450D Dozer
JD 420 track loader
JD35D midi exc.
JD410G TLB
JD450D Dozer
JD 420 track loader
- tuney443
- Contact:
Back to this--does anybody have an idea what might be the culprit here and the parts I might need?
JD35D midi exc.
JD410G TLB
JD450D Dozer
JD 420 track loader
JD35D midi exc.
JD410G TLB
JD450D Dozer
JD 420 track loader
- Paul Buhler
Hi: Try taking a look at your machines parts' catalogue.
type in the model number (440) where asked to reach the .pdf needed. Good luck. Others may be able to share first hand knowledge of your problem, and solutions.
- 440 iron popper
I suggest that the only next move of the crawler would head strait in the garage. I would check if the axle washer (behind the small inner cover) is tight. I had a bad axle bearing lately. The axle came loose. Bearing Rollers went between gears. Result: Everything is Broken.
Once you pull the final, you'll see what the brake band looks like. Maybe oil soaked from the seals being beaten up. If the sprocket wobbles something has to suffer in there... You shurely would check how the clutch pack looks like as well. Look for the transmission/steering case seal also (located in the hub).
I'm right in this actually If I can help! You can go with Lavoy for bearings and other parts.
Users browsing this forum: No registered users and 82 guests
