Starter removal
- fruitcakesa
Starter removal
I have had the starter off my gasser and was able to reach underneath to get to the lower mounting bolt. It lifted out from the top
The starter on the diesel is longer and the fuel strainers are in the way.
What is the trick to reach the lower bolt. Is it accessed from below with the belly pan off?
Does it come out the same way?
196? 1010 diesel crawler, Gearmatic 10 winch w/ arch/fairlead, 6 way power angle blade, ROPS w/rear screen
If like a 2010 diesel crawler (sounds like it is), I removed the bolts holding the fuel filter head assembly to the block without disconnecting the fuel lines. On my 2010, the flexible lines then allow the head assembly to be moved out of the way to access the starter bolt without opening the fuel system to air. You shouldn't need to remove the belly pan- the starter will then come out and up between the block and the side frame.
Hope this helps.
Hope this helps.
- fruitcakesa
Sorry I typed too quick yesterday- I meant to say that you should NOT need to remove the belly pan. I edited my previous post accordingly
- fruitcakesa
Well I dropped the belly pan today
It seems like it is necessary to even see where the lower bolt is
let alone unhook the battery cable and switch cable to get to the bolt
plus I have hydro hoses running around all over underneath that get in the way.
I stopped there because when I tried to start it just for kicks ,after cleaning and tightening the battery cables, it turned over so I buttoned the pan back up, started it, then shut it down in gear so the flywheel and starter gear would random stop instead of shutting down in neutral and have the starter gear hit the usual wear spot on the flywheel.
I will see if it worked tomorrow
2010 has a hole in the frame to get to that bolt ( you might think about doing a mod. to yours) and yes on diesel you have to take filters lose or off to get the starter out unless you have a case 580C filter on it like i do its so mucher nicer
- waterman28
1010 Starter
My 1010 Diesel has a factory machined slot in the frame to get to the bottom bolt and the filters need to be moved also
JD 1010 Crawler
Ferguson TO 30
Case 580C
996 David Brown
Ferguson TO 30
Case 580C
996 David Brown
I forgot to mention the access hole- glad others mentioned it.
Also those diesel starters are HEAVY- it is pretty akward getting them out because you have to fit your arms between the frame and block AND lift that heavy starter out and up. I didn't do this last time, but might be wise to slip a thin strap or something around the starter to help lift it out.
- fruitcakesa
Re: 1010 Starter
Surprise What I took to be only a mounting bracket for the engine covers turned out to also cover an access hole in the frame that someone had conveniently cut.waterman28 wrote:My 1010 Diesel has a slot in the frame to get to the bottom bolt and the filters need to be moved also
I still have to get to the battery and switch leads which might require the belly pan to come back down if I can't get at them from above
Users browsing this forum: No registered users and 135 guests
