1010 Diesel manifold
- gregjo1948
The vertical neck on my diesel 1010 manifold has broken off where it had been previously repaired by the last owner. I'm not sure if I can repair it well enough to last so, I'm looking for a good used one. Does anyone know where to find one and I wondered if the 2010 used the same manifold. Any help would be great. Thanks, gregjo1948
Re: 1010 Diesel manifold
Unfortunately according to the parts manuals (PC0727 for 1010, PC0728 for 2010), the exhaust manifolds do not interchange between the two crawler models or between gas and diesel. It looks like you will need to find a manifold for a 1010 diesel.gregjo1948 wrote: I wondered if the 2010 used the same manifold. Any help would be great.
Did you try PMing this guy for a used one?
http://www.jdcrawlers.com/messageboard/ ... php?t=6905
MacFaddens tractor salvage yard in Sharon Springs NY will have it. I was just there a few days ago checking over the 1010 crawlers for parts. He has at least 8 of them there. Some diesel and some gas.gregjo1948 wrote:The vertical neck on my diesel 1010 manifold has broken off where it had been previously repaired by the last owner. I'm not sure if I can repair it well enough to last so, I'm looking for a good used one. Does anyone know where to find one and I wondered if the 2010 used the same manifold. Any help would be great. Thanks, gregjo1948
- gregjo1948
1010 diesel manifold
Thank you tigerhaze and jdemaris for your replies. JDCRAWLERS doesn't have anything right now and MACFADDSENS hasn't returned my email sent about 4 days ago. I'll try calling, now that, you're quite sure they have what I need. gregjo1948
Users browsing this forum: No registered users and 74 guests
