Hi gang,
Have been using my 40C with a PTO driven hydraulic pump that has been rather funny looking. Also since it is not a live PTO makes working a bit of a challenge.
Finally got a 40C engine driven pump to rebuild. It is in fine shape with no scoring but needed bearings and seals which is a simple fix. Hope it works when it goes back together after all this though. Will make me super happy if it does.
On the input shaft to the pump there is supposed to be a washer and o ring, but when I took it apart it was a 1/2" deep double seal which seems much better in function. It has a CR part number but my 2 local bearing shops cannot match it.
So I plan to put in either a single or (2) 1/4" seals. Same shaft diameter and seal hole.
Thoughts as to whether I should go with 1 or 2?
Krusty,
40C hydraulic pump rebuild
Got my seal from the local JD dealer and all put together and installed yesterday. Since I do not have factory HD lines it is a mishmash of custom made hose and man it is tight for space for those lines the way the intake and exit run up instead of to the side.
Anyways all runs well and am pleased with it. This eve will be spent welding up a tank out of 1/8" plate that would be sized the same as the OEM tank.
Users browsing this forum: No registered users and 70 guests
