MT Valves adjustment
- 440 iron popper
A friend of Mine has a M tractor and he's rebuilding the engine. He asked me about the valves adjustment procedure. On my 440 it's: 1)Align the DC mark on the flywheel with the DC mark on the clutch housing. 2) Check that both rockers are loose on #1. Adjust both valves .015. Turn the crank 180 degrees. Adjust number 2 the same. Is it the same for a M tractor? Thanks.
