1010 reverser problems
Need help i was using my 1010 to push some brush when i went to push the pedal it would not stop, i can shut the motor off and put it in any gear and crank it to move it just dont have a clutch pedal . The pedal just flops up and down with no pressure,i checked where the pedal goes in the reverser and there is no pin sheared any ideas. Thanks
whiteclipse16
I don't know a lot about the 1010 but if it has the reverser I think the clutch is operated hydraulically. The pedal doesn't actually connect to the clutch through linkage like a 440 or later. The clutch pedal pushes a valve or something in the reverser.
Ben
