tranny case trouble
tranny case trouble
so we start tearing into the crawler and realize that the back right hand side of the tranny case was broken and very poorly rewelded. they put some pieces of flat bar inside and then tried to weld it in from the top. the rear plate was also cracked and rewelded. So what is the general opinion, try to replace the tranny case while its tore down?? Also the pinion gear has some small chips out of it. would you guys recommend replacing it?
Home of the free because of the BRAVE!!!
1957 420 5 roller 5 speed
Definitely replace the case if you are that far. Ring and pinion probably, hard to tell without seeing it.
another question.... when i was breaking the tracks yesterday and trying to get the king pin in the right spot both tracks were spinning even with the crawler in neutral, both tranny and reverser. no clutch or motor in it. i wasnt sure if this was normal or if i had some more underlying problems.
whiteclipse16
I think it would be in your best interest to replace the broken case.
As far as both tracks spinning, that should be normal, if your spinning from the sprockets.
This is because your turning through the ring and pinion, the only way to stop one side from spinning would be to pull that sides steering clutch lever.
Ben
No, they will not interchange. I should have a case on hand.
