New user and new 420C
Just saying hello and am very happy to have found this site! Just got a 1958 420C home, 5 roller with gearmatic winch and Holt blade(made in independence oregon) Fresh motor, good undercarriage, broken winch housing. Will post some pics soon. Looking for sheet metal, and I was wondering if these had any type of arch available? Any info would be greatly appreciated. Thanx FS
Fogswamp,
I have a Holt on my '56 420. I'm curious about yours. Does it have the frame outside the tracks? Mine does, but it seems to be a bit large for the crawler. It has, though protected the track carriage units throughout the years.
I don't have a winch, and know nothing about what arches may have been used. I suspect a small stand-alone unit could be used?
Gary
Gary
FS,
Thanks for the info. Sounds the same as mine. I know that it has been in the family from shortly after it was new, so the blade probably came with it.
Interesting that it was done from the factory. That would indicate that there was at least a little agreement from JD about mounting it. I've often wondered.
My blade has so much damage to some of the brace arms that I will have to remove and replace. It undoubtedly saved the little crawler from serious damage.
Thanks.
Gary
Thanks.
Gary
I would doubt that the blades were installed at the factory, they would have been a dealer installed item. Deere had a large number of manufacturers that were consedered "Allied Aftermarket Equipment" manufacturers. What this meant is that their equipment was certified for use on John Deere tractors and crawlers. I have an piece of literature that shows a bunch of the "Allied" equipment, and you can't believe how much stuff the aftermarket made to fit these little crawlers.
Holt made rigid and hyd tilt blades. I have literature for the rigid blade, and had a 420 with a tilt blade years ago.
Yes, when he said "from the factory," I assumed that he meant at a dealer directly after arriving from the factory. I didn't make myself clear. I'm guilty of that, from time to time. Tend to get ahead of myself.
Mine is a fixed blade, a manually adjustable. It does appear to be large for the crawler, but the brackets all seem to be properly done, and everything fits well...aside from where it has been bent from maltreatment.
For the record, I've gone no where on the repairs since last fall. We went south for the winter, and much had to be done on our return. Now, Alaska is in our sights, so I won't get back to the crawler until later in the summer. I have one side all together with the 350 tracks, and it looks as if it will work well. Next step is the left final, and then on to the engine. The blade, itself, will take at least a week, if I don't dally.
bye
Gary
bye
Gary
You are correct in what I was trying to say, meaning they were installed on newly delivered tractors by Holt. Mine also has seen alot of use/abuse.
Lavoy, I see you are from North Dakota, I have some relatives in the Garrison area, One from Ryder who has been very active with the Makoti Threshing show, we just visited there last May, beautiful country. Just a reminder of the Jackson Prairie Threshing Bee here in Toledo, Wa. the end of August, be nice to see some more crawlers there. Well gonna go figure out how to use this digital camera and try to share some photos. FS
Users browsing this forum: No registered users and 140 guests
