8a winch brake
8a winch brake
dose the spring apply the brake then the slave cylinder release it? so when you apply the clutch, the brake slave releases brake, for power in. then when the clutch released, brake cylinder also released,spring presure applied brake is on. to free spool release break by pressure to the brake cyl.
but somhow im missing somthing here.........
8A winch brake
NNAATZ-- If you send me your email address, I'll send you Gearmatic model 8A-8G winchdrum & controls instructions & parts manual. Greg-- gregjo1948@yahoo.com
gregjo1948, you aready sent me one. thank you. i found the drawing and operation instructions alittle vague, had to read it several times to understand it, and trying to visulize the functuon of missing parts, mainly the brake rod springs and tube and how it contacts the band. i found some parts others will need fabrication. any pics will help
thanks nick
thanks nick
Kind of dorky to look at this way, but when the winch is spooling in, the brake band is self unapplying for lack of a better term. When you stop and try to spool cable out, the brake self applies, therefore you have to manually release the brake so the drum will turn the other direction.
yes that does make sense thanks. i got some parts, trying replicate others. i read through the manual again. found out that there are 2 tubes, 1 with the spring and adjuster to hold tension on the band, to help create brake action (thats on the bottom). the 2nd tube comes from the slave to break the breaking action, then rod that runs through the holds the tubes in line...corrrect??????
That sounds about right. I do have at least some parts available if need be.
Users browsing this forum: No registered users and 138 guests
