420C
- gregjo1948
420C
There is a 420 on CRAIGSLIST in Leyden,NY. It has 3 rollers p/track and a single lift cylinder for the blade. It doesn't have the pressed steel pads. They are the newer type. Does this sound like a 420 or is it an MC or 40C with newer style pads? I thought the 3 roller machines were only MC. gregjo1948
Re: 420C
I noticed that listing on Craigslist too. I would of thought that it was a 40C.gregjo1948 wrote:There is a 420 on CRAIGSLIST in Leyden,NY. It has 3 rollers p/track and a single lift cylinder for the blade. It doesn't have the pressed steel pads. They are the newer type. Does this sound like a 420 or is it an MC or 40C with newer style pads? I thought the 3 roller machines were only MC. gregjo1948
I am guessing it is a 3 roller 40.
- gregjo1948
420C
I didn't know if they made a 3 roller 40C. That would explain the newer pads. Thanks, gregjo1948
Definitely an MC.
Lots of MC's had their pads changed at some time in their life. Also, very late MC's came from the factory with late style pads.
- gregjo1948
420C
This machine is on EBAY now also! I suggested to the seller that it might be an MC and I'm wondering if he will reply as to why he thinks it's a 420. gregjo1948
Re: 420C
Maybe we are all wrong, he says he replaced the water pump on the eBay listing. Maybe it's a 420 with a MC undercarriage. Who knows!gregjo1948 wrote:This machine is on EBAY now also! I suggested to the seller that it might be an MC and I'm wondering if he will reply as to why he thinks it's a 420. gregjo1948
If you blow up the pic, you can see the lower hose is smaller, so it has a 420 engine. Trans, dash, undercarriage and such are definitely MC.
- gregjo1948
420C
The owner replied back to me and said the engine is a 420 but doesn't know, after I suggested it might be a MC, what the machine is. Don't the MCs have a tag on the dash stating the model? gregjo1948
