440 gas wiring diagram
Topjimmy02
Post by Topjimmy02 » Wed Feb 27, 2013 10:36 pm
Does have a wiring diagram for a 440 gas crawler? my book disappeared and all i can find is a 40c or 420 wiring diagram with wire colors on it. I dont know if they are close enough to use or not?
I am trying to unscramble someone custom wiring job and put it back to somewhat original. any help is appreciated.
Thanks.
DukeofDeere
Post by DukeofDeere » Thu Feb 28, 2013 8:49 am
If you have the 420 diagram I think you have all you would need to git er done.
May be worth just rewiring all of it.
I don't recall if anyone has the wire loom for these machines.
Quite simple though.
Duke
Post by Paul Buhler » Thu Feb 28, 2013 5:30 pm
Lavoy has access to new wire harnesses. I bought one from him for my 420; soldered connections, color coded and clearly labeled. The swap on my machine went quickly and works well. Paul
whiteclipse16
Post by whiteclipse16 » Mon Mar 04, 2013 1:08 pm
Yes a 420 I would think would be the same.
I'd just rewire also, there's nothing to these. Generator, coil, some switches, and gauges.
Ben
Post by Lavoy » Mon Mar 04, 2013 4:24 pm
440 will have oil pressure gauge wire, and some leads may be different length, but concept is the same.
