1010 Hydraulic Pump
1010 Hydraulic Pump
I need a replacement pump for my 1010c dozer and was curious what others were using as a replacement pump.
I'm not sure of the make but it is marked B15512 1YK and 1 40 HS.It's a 9 spine and I think 5/8.It blew the pump seal.
John
John
- gregjo1948
1010 hydraulic pump
I think my 1010 has a Cessna pump. Why don't you replace the seal? gregjo1948
It's going to depend on whether you have a dozer or loader. The loader requires larger flows. Read Jdemaris's response in this thread:username wrote:Does anyone know what specs I am looking for in a pump such as gpm,psi and frame size?
http://www.jdcrawlers.com/messageboard/ ... ght=cessna
Sorry, I missed the word dozer in your original post. The size differences (shaft OD and spline count) depends on whether a bare dozer or dozer with capability for attachments, and that dictates flow rate. Bare dozer is the 15 GPM @ 2500 RPM; dozer with attachments is the 23 GPM @ 2500 RPM. Part numbers are in the discussion thread I posted.
Users browsing this forum: No registered users and 43 guests
