Saw this tilt set-up on a 1010 and since I'm in the process of making my blade hyd angle on my 420, I thought it would be nice to have hyd tilt. I can manually tilt blade now. I could make this system, thats in the pic, work if I could find the pieces to mount on the blade, the rest I can build. Anybody got an idea where I could find the parts? My local JD isn't of any help. Thanks.
Cooter
6 way blade parts needed
- 1954cooter
Those pieces pretty much don't exist, they are one of the first pieces broken. The last ones I bought for my own blade were a few hundred dollars, so not cheap. If you use them for hyd tilt, they WILL be the first pieces broken. They are not designed to be a sliding piece all the time, only to adjust the blade, then locked in place again.
Users browsing this forum: jimmydiesel and 117 guests
