repair to 440 cast nose
The heavy cast front nose on my 440 has broken mounting brackets. I'm not sure if this nose is cast iron or cast steel. Most of each bracket is OK but the brackets are broken off where the bolt hole was drilled. (so just the very end of each bracket is broken off). Does anyone know of a good fix for this. Thanks.
Machinery hand book recomends brazing for the repair of cast iron, and I've had good luck with it. If one prefers welding a Palco 808 is a good cast rod that I've used, however there is a ton of ways to repair cast iron the way that suits You is the best.
Users browsing this forum: Google [Bot] and 184 guests
