6 Volt Battery Recommendation
- Roger440IC
I'm finally replacing my 6 volt battery on my 440-IC. Does anyone have any recommendations on a good HD battery? Are there any batteries out there that have side-posts so that installation/removal and charging isn't so dicey?
Thanks, Roger
Thanks, Roger
440-IC
420-U
420-U
What is wrong Roger; don't you like scraping your battery posts against a gasoline tank when you install or remove it?
I have had good service out of 6V batteries I bought at NAPA, but there may be other alternatives. Doubt that you will find General Motors style terminals on a 6V battery. Gil
P.S. I keep a small float charger (not a trickle charger) on all my 6V batteries constantly and they are always ready to go, summer or winter. Does not seem to hurt the battery life. Walmart should have them in stock for $20.
Far and away over the last 20 years I have had the best luck with the Deere battery. I know it sounds stupid, but we have run every brand out there, and normally get 1-3 years out of any other brand. We seem to get 5-6 out of the Deere batteries. They also have the highest CCA that I can normally find.
- Paul Buhler
Hi:What is wrong Roger; don't you like scraping your battery posts against a gasoline tank when you install or remove it?
I've used a short piece of bicycle inner tube with a slit in it over the "hot" terminal to help avoid the sparks that Gil is referring to. It will stretch to fit over a made-up terminal or a soldered one. I hang on to the plastic terminal caps and use them when I need to lift out my battery.
I've used Interstate Batteries with good success - the dealers are usually knowledgeable and can help with the proper size selection.
Battery
I would also endorse the deere battery, spendy, but works good. I personally will never use a interstate battery on any of my vehicles again. worked great for 1.5 years then it quit. warranty was a pain itn the a**! they are supposed to have "free replacement for the first two years". But the rep said it was more than 2 years old, even though my receipt stated 1.5 years.
They skip out on warranty any way they can. The product isn't worth the price.
My deere battery cranks my crawler over whenever!
1950 mc crawling around
If you search for "battery" using the search function, you can find a number of archived threads that discuss different manufacturers and brands of batteries and other considerations when selecting a battery for offroad/crawler use. There is a different bewtween a typical automotive battery and one for offroad use, although you likely have fewer choice for a 6V battery than those looking for a 12V battery.
Over the years I have noticed that the batteries that have lasted the longest for me are tractor/offroad and have typically been heavier than similar batteries in the same group, presumably due to thicker plates that are less resistant to cracking from vibration. Of course when I say that I am mainly discussing wet cell batteries and not the "gel" type like Optima.
- Roger440IC
Gil, I have to admit that I do enjoy that little extra excitement when the wrench slips and hits the bottom of the tank while loosing the bolt on the battery cable. It's a coordination thing...
Thanks for the input guys. The local Napa store has a 950 CCA battery for $105 that is 9 3/8" high. I'll also check to see what Deere has. Roger
440-IC
420-U
420-U
Check your other dimensions, that sounds like a large case battery.
I have never seen a small case 6 volt over 700 amps.
- Roger440IC
Length seems long, seems to me more like 11" or so long.
- RacinJason
Battery
I've been using the 12 V battery from my 06 Silverado HD in my 420 C. It seems to stay charged, tho I'm still running the 6 V generator. (Got an 8 year old Optima in the truck) The #75 has side terminals, so wont torch my dozer. Also, no lights on the 420 or the battery might not stay up. I think there is discussion on JD Crawlers regarding an 8 V battery. The CCA seem less than the 6 V, tho.
JD 112, JD 420 C
- DiggerLarry
- Contact:
- RacinJason
Battery tenders
I have several battery tenders I got on sale from Harbor Freight, but haven't used them, as the 420 was up in the woods. It's in Maine and I'm in Spfld, MA. It is now parked behind the garage so that I can plow snow, if need be, and I'll be plugging it in when I go up next week.
JD 112, JD 420 C
Users browsing this forum: No registered users and 33 guests
