440 large vs small tranny
wizner85
Post by wizner85 » Sat Jul 19, 2014 5:52 pm
Well, just found out if you put a large style tranny as a replacement for the small style, you will be an inch off on attaching the bell housing and engine to the c channel. Took me two hours of measuring to find the small tranny is literally 1 inch shorter length casting than the larger style. So now the engine sticks past the mounting holes on the c frame by an inch. Holy xhxhxhsjdjxhshsjdhdjs john deere you couldn't make the jfhdjdjfhdkkxjxjdhdjxjsjxjdj casting the same length???
Not sure if anyone knew this or not, but if you are piecing a 440 together from pieces like me, then now you know.
Only easy solution I see is drilling new holes to mount engine and bell housing, since I am 65 percent back together now.....
Hoping hood fits correctly now, and rad clears front casting..
440 ICD 64 blade & 8a gear attic winch
440 ICD 831 loader with scarifier and weights
420 62 blade 3pt
Looking for 24 scarifier and 440 log arch
Post by Lavoy » Sun Jul 20, 2014 9:18 am
I think you will find that it will not work, buddy of mine went though this years ago.
DukeofDeere
Post by DukeofDeere » Sun Jul 20, 2014 9:21 am
I have a small transmission on a parts tractor in you need one
Duke
scampr
Post by scampr » Sun Jul 20, 2014 12:11 pm
Ok now you have me nervous.... are all the diesels the same..i was going to put a later 5 spd in to replace a early 4 spd..... both are diesels so i thought they would be the same... now i am nervous.
scampr 440icd, 350B, 47 Farmall H, 55 Farmall cub and ashamed to have a Kabota too
wizner85
Post by wizner85 » Sun Jul 20, 2014 4:04 pm
From what I'm told large tranny has a 4 bolt plate over the ring gear. So if both have this plate I think you are fine. Not sure when small tranny was stopped. I'll let everyone know how much fab work is involved with this... Worst case I think the hood needs chopped by an inch......
420 62 blade 3pt
DukeofDeere
Post by DukeofDeere » Sun Jul 20, 2014 5:37 pm
A power increase at serial # 448001 changed the drivetrain.
The diesel was added then as well.
The trans is 1" longer in my later 440IC with a 4 speed than in the early 440IC with a 5 speed.
Just what I could check and measure.
Duke
Post by Lavoy » Mon Jul 21, 2014 9:49 am
All diesel and gas after 448,001 use the large tranny. At this time, the reverser case changed to larger studs, and the side frames to accommodate the longer transmission. There are likely other changes at the same time.
scampr
Post by scampr » Mon Jul 21, 2014 2:51 pm
Thanks Lavoy once again you got my blood pressure under control I just bought a late model 440ICD with a loader as a parts machine.. for my 440 ICD dozer.. I was planning to use the reverser and trans,and a few other parts.
