Back in the game......JD 440 IC
Grille is homemade, pads look nice, good looking crawler.
Looks like plenty of adjustment left on the tracks. What is the front attachment? Looks like a brush ripper. Does the winch work? gregjo1948
Early crawlers are just a piece of heavy expanded mesh, late crawlers have a flat steel plate similar to what you have.
On a late crawler, yes.
Sooo....I also got the Original operators manual for the crawler, it is a 1958 SN 441146 and the instruction manual for the 8A winch, very happy. What I have read the early ones have the small transmission. Is this an issue? It has been sitting for two years without any use, should I change All the fluids and filters? Another question for you cold climate guys, as it will be going to my place on the east side where it was 3deg f last weekend, any tips or tricks? Thanks for your time.....
I haven't read of any small transmissions issues on here.
As for cold weather, since you're a gas make sure you have a good battery and she's tuned up properly and I think you'll be fine. Lots of guys on here don't have issues when it's cold.
If you really wanted, you could buy a dipstick heater or some stick-on heaters for the oil pan. That might help get a little warmth in the engine and make it easier.
Ben
I have a way to put a block heater in if you want, works great.
- Paul Buhler
Users browsing this forum: No registered users and 113 guests
