440 sprocket
- Paul Buhler
- mapaduke@yahoo.com
Thanks scampr it probably wouldn't work very well with all the other crawler parts out there. it would be like trying to find a perticular needle in the hay stack. lol
I ended up shimming the sprocket on the good side so it would turn more true then ground the side of it so it wont rub on the rear role, now I can move it around and get the loader back on and the hydraulics working.
Some time in July when the snow is finely gone I will find the good one and swap it out.
nothing crawles like a deere
Back to Lavoy's post about hanging the machine by the sprocket---I bet you could hang it by the sprocket and not damage it. I'm thinking, (1st time this week) the bend happened by a sudden impact rather than a heavy pressure. gregjo 1948
Are these sprockets hardened? Seems like they are. I know when you smack one with a hammer, it really rings. I've never come across a bent one but, I've seen teeth broken off. We'll probably never know how the sprocket got bent so, make up a story and stick to it. Giving me a brain ache thinking about it. gregjo1948
My guess would be it was stuck, and someone hooked a chain to the track or sprocket and pulled it out with something large enough to bend it.
Users browsing this forum: No registered users and 110 guests
