Need help finding exact year?
cumminsz28
Hey yall, as you can see im new to the forum. I inherited John Deere bulldozer. I have tried to look up the serial number and model number. I cant find any information on it anywhere. Id like to find the exact year so I can get a manuel for it. On the serial tag it says T4F3D (type) 074056T (serial). Help would be greatly appreciated!
Red
Red
Looks like it is a 1968 350 crawler dozer diesel with hi/low revers trans http://www.jdcrawlers.com/messageboard/ ... al+numbers
cumminsz28
cumminsz28
i was thinking 2010/450 HLR ....on 350 i believe it would be a reverser
what would i be looking for if it had the hi/low reverse?...can you go from forward to reverse with out using the "clutch"? if so you have a reverser
cumminsz28
Yes I believe it does have reverser, but I still do use the clutch ha. Do y'all know if there's anyway to make adjustments to the transmission without removing it from the unit itself? One day sit seemed like it had no power going forward, now won't move forward and made a grinding noise. But the doze moves fine in reverse?
cumminsz28
i dont know if you seen this or not http://www.ebay.com/itm/JOHN-DEERE-350- ... 3a808d0201
