JD350 thru JD350D Serial Numbers
Facts and knowledgebase about John Deere crawlers
Re: JD350 thru JD350D Serial Numbers
Post by Jim B » Fri Jan 10, 2020 6:01 am
Welcome to the board.
I can't say you will find any thing for numbers stamped in your housing, but you should review this post from last month. viewtopic.php?f=8&t=13074 Check out the last reply from CatD8RII.
Rangervan
Post by Rangervan » Sat Jan 11, 2020 9:07 am
Thank you. I'll look at the transmission housing after I pressure wash the rest of the machine off.
