Need help finding exact year?
Facts and knowledgebase about John Deere crawlers
cumminsz28
Post by cumminsz28 » Tue May 21, 2013 10:14 am
Hey yall, as you can see im new to the forum. I inherited John Deere bulldozer. I have tried to look up the serial number and model number. I cant find any information on it anywhere. Id like to find the exact year so I can get a manuel for it. On the serial tag it says T4F3D (type) 074056T (serial). Help would be greatly appreciated!
Red
Post by jtrichard » Tue May 21, 2013 11:27 am
Looks like it is a 1968 350 crawler dozer diesel with hi/low revers trans http://www.jdcrawlers.com/messageboard/ ... al+numbers
cumminsz28
Post by cumminsz28 » Tue May 21, 2013 11:37 am
thank you a million!! now i just need to find manuals for it because, i need to know how to adjust the steering, and theres something goofy going on with the transmission.
Red
cdunn
Post by cdunn » Tue May 21, 2013 10:07 pm
I'm not sure about the hi/lo revers transmission you mentioned..
57 420c 86 Ford 4600
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
cumminsz28
Post by cumminsz28 » Tue May 21, 2013 10:12 pm
what would i be looking for if it had the hi/low reverse?
Post by jtrichard » Wed May 22, 2013 11:38 am
i was thinking 2010/450 HLR ....on 350 i believe it would be a reverser
...can you go from forward to reverse with out using the "clutch"? if so you have a reverser
cumminsz28
Post by cumminsz28 » Thu May 23, 2013 7:51 am
Yes I believe it does have reverser, but I still do use the clutch ha. Do y'all know if there's anyway to make adjustments to the transmission without removing it from the unit itself? One day sit seemed like it had no power going forward, now won't move forward and made a grinding noise. But the doze moves fine in reverse?
Post by jtrichard » Thu May 23, 2013 11:38 am
some adjustments can be made BUT (you HAVE ordered a book by now?) ....you need to read up on the adjustments before you get started
cumminsz28
Post by cumminsz28 » Tue May 28, 2013 9:28 am
No I havent bought a book yet, i needed to find out exactly what year it was before i went anywhere with it. I just wanted to make sure that it was able to make adjustments or to see if it was just a lost cause. Now im just searching for books that arent going to break the bank. haha
Post by jtrichard » Tue May 28, 2013 10:58 am
i dont know if you seen this or not http://www.ebay.com/itm/JOHN-DEERE-350- ... 3a808d0201
