Gearmatic 8A Winch Parts For Sale
JDCrawlerdog3
Post by JDCrawlerdog3 » Sun Apr 15, 2018 6:08 pm
Gearmatic 8A winch parts for sale:
Gear Cover with Bearing Cap Screw – Good shape - $50.00
Clutch Cover with Bearing Cap Screw and Hydraulic Gland – Chip out at one bolt hole - $75.00
Clutch Bands – Both primary and secondary, need re-lining, bands in good shape - $20.00
Clutch Spider – Two clutch adjusting bolt holes need to be drilled and re-tapped, and two guide plate bolt holes need to be drilled and re-tapped, three clutch band guide plates included - $90.00
Clutch Lever Arm – Good shape, no cracks or welds - $100.00
Master Control – Housing only with cover, no cylinders, has internal lever and shaft - $75.00
Master Control Handle – Splines good. No rubber grip - $75.00
Brake Rod, Spacer Tube, Spring Saddle – Rough but serviceable - $20.00
PM me for pictures.
Thanks.
Andrew
jdtech
Re: Gearmatic 8A Winch Parts For Sale
Post by jdtech » Fri Feb 22, 2019 8:02 am
Some parts missing on my gearmatic 8A wondering if you still have parts available ?
JDCrawlerdog3
Post by JDCrawlerdog3 » Sat Feb 23, 2019 5:56 am
Jdtech,
PM me with a list of what you need. No longer have master control, handle or clutch lever arm.
Andrew
Post by Lavoy » Mon Feb 25, 2019 10:48 am
I have some new reproduction parts depending on what you need.
