Low pressure grease guns now in stock
Post by Lavoy » Tue Nov 06, 2018 5:00 pm
Now in stock, low pressure high volume grease gun with button head fitting, $60 + freight.
dtoots1
Re: Low pressure grease guns now in stock
Post by dtoots1 » Wed Nov 07, 2018 1:25 pm
can you post a pics of the low pressure grease gun and dimensions? what size tube or cartridge is used? i have an old one and need cartridge for it.
i refill an old cartridge with the 00 spindle grease, messy but it works!!!
thanks
Dennis
Post by Stan Disbrow » Wed Nov 07, 2018 1:51 pm
Deere Corn Head grease comes in the standard size cartridge. Probably what size the guns Lavoy now has uses. That being the same size the high pressure guns use. My Alemite 4015-A uses the standard size. They also have the 4015-B which is longer and holds more and meant for loading from bulk. Maybe you have a long one?
Post by Lavoy » Thu Nov 08, 2018 9:55 am
Cartridges are standard size, any cartridge you find at an auto parts store is the same size as the corn head grease cartridge.
Users browsing this forum: No registered users and 120 guests
