JD 1010 bulldozer / crawler for sale. Gas 4 cyl engine with 6 way blade. Reverser / clutch went out and don't have time to fix. Use Lavoy parts to fix it! Was using it to do grading work for a new house in the mountains and had about 100 / 120 hours on it. Starts right up, runs and blade still works, just won't move. If you push the clutch in, no sound from the trans. When you put it in gear, and you can feel the gears turning, and then let the clutch out, it makes a rattling type noise and won't move. Carb rebuilt, new battery, etc. Rippers on the back of the blade. Great dozer. Would keep it but am in the middle of a house build. About 6' wide X 10' long and 8000 lbs. $3500.00 obo. Located in Lakewood Colorado. Picture can be seen on the Denver Craigslist ad.
FYI- Great site Lavoy! Been on here to fix some of the smaller issues I had. Thanks!
FOR SALE JD 1010 in Denver CO area- $3500
Re: FOR SALE JD 1010 in Denver CO area- $3500
Glad to hear it.
It might be the isolator has let loose and will make just enough drag to turn the input shaft. Not an expensive part if that is the case.
Users browsing this forum: No registered users and 71 guests
