Now in stock, T10198T, T10197T reverser pinion shafts for the clutch type reverser, very late 420, 430, 440. These are the shafts that go through the pinion gears in the center "differential" of the clutch type reversers and get ruined when they are run low on fluid. I also stock the bearings for inside of the gears themselves. These are not cheapo soft shafts, they are correctly made, air hardened tool steel.
Shafts are $75 each.
Call 701-361-1006 for more info.
In stock, 440 reverser pinion gear shafts
Users browsing this forum: No registered users and 129 guests
