reb
Post
by reb » Fri May 02, 2008 9:04 am
I am looking for a pto shaft and related parts for my 450C crawler loader. It currently has just a block plate where the shaft goes. The JD part number for the shaft is : T20948 SHAFT,POWER
Thanks, Ross
JD430C
Post
by JD430C » Fri May 02, 2008 9:57 pm
hi, i have a 450C parts tranny with the pto shaft, if i still need one let me know and i will try to take it apart this weekend.
andrew
reb
Post
by reb » Fri May 02, 2008 10:05 pm
Andrew,
I need the shaft and related parts(the outer bolt on housing etc) to convert my non pto 450c. What would you want for the parts? Thanks, Ross
jbrown
Post
by jbrown » Fri Aug 01, 2008 5:51 am
Did you ever put that pto shaft in your dozer? f so how hard was it ,in the service manual its says you have to pull motor. is that so?
Post
by digitup2 » Sat Aug 02, 2008 6:57 pm
Last couple I installed I backed it up on a 8 inch log and pulled the back plate then installed the shaft ,If you get the rear up high enough [a foot even ]you will not lose any oil and you can work on it easyer even .Digitup.
Users browsing this forum: No registered users and 68 guests
