Listing for a friend, 3PT hitch, nice shape, several new parts. Does not have top link, or correct sway chains and clevises.
Hitch is located in ND, any questoins, let me know and I will get you the answer from the owner.
3PT hitch for sale
Bryce,
I believe it is now sold, but I might have another one in a month or so.
These hitches fit 40 after 62,263 up through 440. They will fit on a loader, but require some more thought in the installation. There is no way to mount the cylinder bracket. I have seen pics of them on a 90 loader, and they weld a tab on the loader frame to hook the cylinder to. Other problem is lack of hyd to run it. It really should not be hooked into the loader hyd unless you use a pressure reducer. The loaders operate at a higher pressure, and would increase the lift capacity too much.
Users browsing this forum: No registered users and 122 guests
