Anyone know where I can find a throttle cable for my 450??. I recently purchased the machine, but found the cable is seized/rusted pretty bad.
I get very little movement to the pump.
Looking for JD450 throttle cable
Unless you can find something like a PTO cable at a truck shop that will work, pretty much a Deere only item that I know of.
Here are some cables that you maybe able to match up to http://www.ebay.com/itm/Steinjager-J001 ... 04&vxp=mtr (change to your ends)
JD part # AT 105279 ... is 48" long and #AT 83335 ...60"
YOU can also Google the JD #s and a lot come up also you can have them made to order
also MCmaster carr has them http://www.mcmaster.com/#push/pull-cont ... le/=wmx1x2
Cable repair
I attach a hose over one end of the cable and clamp it down with a hose clamp, spray in some fluid film and then insert and clamp down our air blower nozzle and apply some pressure. I go from the pump end. You know it's working if it takes more air after sitting over night. Will not fix all cables. I have 2 machines on deck that will get this treatment shortly.
Normally the cables just get rusted up. My dad would soak the cables in oil, but this is much faster. About half of the machines we get in have sticky throttle cables. Much quicker and cheaper than replacement.
After market cables often require building a new mount for the pump end but can be done. I have even seen choke cables used.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Users browsing this forum: No registered users and 127 guests
