4020 540/1000 brushhog question
- lurch85
have an older brushhog, 540 of course, 5 foot.
To get the RPM"s up to where it cuts like it should, have to get the engine rpm"s up of course, feeling like i"m just wasting fuel. And at 45 horse, I definately have more than enough power (tach doesn"t work, so i"m guessing at what speed I"m atually at)
Question is, would I be further ahead to use the 1000 rpm with a clutch, running at lower engine rpm?
Any potential problems that I haven"t thought about?
John Deere 420C, John Deere 350 straight with Gafner loader, John Deere 4020
Yeah. Just run the engine low enough so the 1000 rpm pto is 540. The new machines have an Economy pto setting where you move a lever and change the pto gearing, the there is another mark on the tach for running the engine slower and have 540 at the pto.
Of course, the 4020 1000 pto shaft has finer splines, and I don't recall that you can get 1000 rpm without swapping the shaft. I think the shifting of speed is performed by the shaft in the 4020. So, I think you'd need to change out the yoke on the brush hog. I haven't run a 4020 since I was a teenager, but when I did it was with a 1000 rpm baler, so I do recall swapping the shaft out.
4020 is 90 HP, so you have plenty to spare. We have done just what you are talking about for many years on 4020's, just not on a mower, but in your situation, it will work fine.
I would buy a tach, I can get new aftermarket, they are not expensive, then you know where you are at.
FYI, if you run the throttle to the first stop, that is 540RPM on the PTO.
- lurch85
Definitely agfee that I should get the tach working. .. how much for the cable and how much for the tach? I have to check it out first anyway.
Doing this depends what I find to work with shafts wise.
Lavoy.. got any used shafts? (540 or 1000) 4 ft ish
strong enough for the 4020 and or with clutch
Just so you know, I presumed you had figured out the HP you would have at the reduced engine speed.
New tach is $190, cable is $25.
If your shaft is good, I would just get a 100 to 540 adapter, not spendy, I can get you one locally here if you can't find them.
- lurch85
actually.. in truth... I should say the brushhog itself is not mine. I get to use a buddy's equipment in exchange for fixing his stuff...
He has the shaft that came with it, (probably not more than 45 hp or so, and i'ts starting to look rough) and I use a soft bolt for the shear pin.
I really need to get a shaft of my own for anything else i'm going to use... (redoing some of my dad's old equipment of varying hp requirements)
Hoping to just get a good strong shaft and use whatever adapter is needed. (That was the idea of using the smaller clutches to protect whatever piece of equipment i am using at the time.)
I can source new complete shafts, but nothing used.
