It has a voltage regulator separate from the alternator....is not charging and need to know how to test voltage regulator and alternator.
thanks
dtoots1
david brown charging issues
Re: david brown charging issues
The ignition switch feeds power to the cut-out of the regulator. Make sure there is power there first. Then, the regulator feeds power to the field coil of the alternator. Check that line with a voltmeter and see. If you don't have power there, the regulator is bad. If you do, then the alternator is bad.
Thank You Stan you the man with all the electrical knowledge!!
thanks again
dtoots1
thanks again
dtoots1
Users browsing this forum: No registered users and 51 guests
