This is a JD 350-c that is FOR SALE near home here in australia for A$24000 or US$30000 which I feel is FAR TOO EXPENSIVE...I think the value is about $15000 tops!!...nice little dozer thou...tight under-carriage and good mechanically I feel!.....it worked all its life in forestry department and well maintained.
NOT SURE IF THIS WILL WORK????
JD350C 6-WAY Blade & 3Pt Hitch
JD 450-6 WAY BLADE and RIPPERS
JD "A" -46
JD "40-S" -55
LANZ BULLDOG MODEL-H 2418
JD "A" -46
JD "40-S" -55
Fred, check out this topic: http://www.jdcrawlers.com/messageboard/ ... c.php?t=45
It talks about how to upload your photo to a server the board runs and then link to your pictures.
The link you posted is off of your computer and you can't host pictures that way unless you run your own web server (which I imagine you don't).
