Here is a 350C dozer that I am fixing up for myself. I think it once was a government forestry machine as it came equipment with a true PTO and rockshaft.
Work done to date:
- replace rails with 90% used rails that we had in stock, plus pads from a for sale 350C crawler dozer that we finished a month ago (rails were shot on for sale machine, pads were better than my original)
- replace sprockets from a 350B widepad deconversion, mine were about 50%, these look fairly good to me
- drill and tap broken bolts in sprocket covers
- replace top rollers and idlers from a 350 dozer that we will be rebuilding this winter, getting new idler seals this week
- drill and tap spring cover bolts, will be putting an order for them in shortly
- install limb riser package from a 350B outside mount dozer machine, need to remove and re-weld the non-exhaust side as 1" too low. Thought I had it right, but when our welder finished it wasn't right. I guess I should have measured better
Work to be done yet
- finish refurb on front idlers
- track frame bolts have been removed, will be grinding the bushings down to match the wear on the cross member mounting holes, re-install and then weld the bushings to the crossmember. The new bushing were just install by previous owner, but not effective as there was a 1/2 gap appearing when putting down pressure on the dozer
- install new spring covers
- finish exhaust mounting, need to drill and tap the exhaust side top mounting
- hammer my grill screen flat, or steal one from a rebuild machine
- locate 3 point hitch parts, really only have the rockshaft, cylinders, valve and lower arm mounts, so basically need the expensive parts. If I can't find the parts, I may remove the rockshaft and install a ripper for now, might as well have something to operate with the extra hydraulics
- order new seat
- remove stump pan and get rid of the debris
- change rad out, this one has been repaired but I would like to put a non-repaired one in
- locate 1 good "John Deere" name plate for the hood, 1 is absolutely mint, have better which I'll put on for now
- remove blade and rebush, might skimp out and get by with removing some shims on the dozer mounting
- install factory lighting
- remove steps and straighten
- change all fluids
I am really trying to get this back to as close to a factory looking machine as possible. Parts costs have been nothing so far, but used up some good undercarriage and a few weekends here and there. For the most part, it is was a nice workable dozer with 50% undercarriage when I started. I do plan on dissasembling and getting it professionally painted in the future, but for now I will settle for a good clean functional dozer.
Next project (my first green crawler) has already arrived, so need to get this one wrapped up.
I could use some help on finding the 3 point hitch parts, so if anyone knows of any parts available please contact me. I'd really like to try out a rough cut mower behind it.
JWB 350C Rebuild Program
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Nice looking project you have there Jason.
That is the first green 350 I have seen and I sure like the look of it. Was the white rops the original color? I can't tell from the photo what the original colors on the undercarriage were as well. I see some green there and a yellow spring? I could just wait until you have it all painted up but my curiosity is getting me. I tried to find a photo on the net without success.
It always seems odd to me that Deere used so much yellow on their construction equipment when they have such a good reputation for quality equipment branded in the green color. Perhaps it is a safety issue, the bright eye catching yellow in the workplace?
The green is nice.
If I see anything out here with a three point hitch, I will let you know.
The green is nice.
backhoe attachment.
backhoe attachment.
I make some new 3PT parts.
Users browsing this forum: No registered users and 66 guests
