I ran across photos of this setup on Epay and thought it was worth sharing; it's amazing what people will fabricate in the shop as I assume this was not a factory setup.
http://www.ebay.com/itm/1987-JOHN-DEERE ... 309wt_1170
Unique Hoe Counterbalance Setup on 350 Widepad Crawler
could have been factory built... the weights they used are JD ....looks like it was built for STEEP hill side work ....it has been listed numerous times not much interest ..i like the track spring on the right side
Looks like the fuel tank has been moved as well.
9300 hoe
A 9300 hoe is very heavy even for a 450C. With a dozer and a 9550 hoe they are an okay setup, but still needs weight on the Dozer to balance the machine.
Should get a cross wet ground nicely.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Users browsing this forum: No registered users and 68 guests
